95 suburban grinding from transfer case?
Old Jul 20, 2016 | 11:36 AM
  #21
Zeppelins2's Avatar
Could you please send me your instructions. This will be the third time and over $2,000 later that I'm replacing the Transfer Case in my 1995 Chevy Suburban. It's greatly appreciated. Thank you.
Old Jan 28, 2018 | 6:53 PM
  #22
Triton Madden's Avatar
Originally Posted by transguy37
Hello,
There is a lockring the breaks right in the little tailhousing on the back. This lockring holds the main shaft in place, when it breaks the shaft will move with motion. All the gears and synchros are on the main shaft and lets the gear it the slider ring and grind. They make a fix for it so it will never do it again. If you are interested in checking or fixing it, let me know and I can tell you how step by step.
Im experiencing the same thing plz help how to fix and what should I do I'm about to take it to a shop don't want to if it's an easy fix my phone number is 4802440774 thank you
Old Jan 28, 2018 | 6:56 PM
  #23
Originally Posted by bossman78
Recently the truck will grind when taking off from a stop. This only happens in 2-hi and when in 4-hi no noise is heard. Sounds like the grinding is from the transfer case area. The truck has the floor shifter. Does anybody have knowledge of possible electric failure or likely a mechanical defect?
how did you the problem
Old Dec 26, 2018 | 7:42 PM
  #24
Jackson Ellison's Avatar
Default Please instructions
Originally Posted by tgmg2
I have the same problem ON MY 95 SUBURBAN it breaks once a year going into the shop today, part cost $7 bucks and about $100 to have it done I WOULD LOVE FOR YOU TO GIVE ME A STEP BY STEP ON HOW TO FIX IT....THANKS
It sounds like you may have the same problem. If it hasn't worn the teeth off the slider ring from grinding, you don't even have to pull the transfer case out. You can pop the little tail housing off and fix it in the truck. That's the cheap fix. I f you have to pull the transfer case off and replace some parts, it could run anywhere from 800 to 1200 with labor and parts.
ease. If still available I would like step by step instructions.
I'm new to trucks. I work in cars. Front wheel drive. Time to learn this.
thanks.
ibhave a 94 chev suburban. Same problem exactly
Old Dec 26, 2018 | 7:52 PM
  #25
thanks.
my email is jacksondellison@gmail.com
or number at 206 992 4645
thanks. Trying to fix this before next quarter for school starts.
dslemaire
Aug 23, 2018 9:46 PM
ph4ze
Aug 4, 2012 2:17 PM
stiffrm316
Aug 12, 2011 2:13 PM
Lukes_chevy
11
Nov 23, 2010 12:17 PM
rowekmr
Aug 7, 2009 12:18 AM
