95 suburban grinding from transfer case?
Old Mar 19, 2010 | 9:04 AM
  #11
73SS's Avatar
The Sonnax part number is 100420-01K for a 1.180" diameter shaft or 100420-02K for a 1.375" shaft. I got the parts from a local trans repair shop. It was simple enough to drop the t-case off and then drop the trans tail shaft housing off and replace the snap ring. I found the old snap ring in pieces in the tail shaft housing - good clue to the problem. You can probably google the part numbers. There is a good schematic picture that comes with the repair parts.
Old Jun 26, 2010 | 10:19 PM
  #12
FRENCHEVY's Avatar
I believe having the same problem for a couple days now , i thought the noise came from transmission , but then i check my crankcase oil and it was full of tiny little pieces of metal . The noise it's like trying to put in gear a manual transmission without pressing the clutch , that's how it's sound to me . I'll check in the morning , I really like this site .
Old Jun 26, 2010 | 10:33 PM
  #13
FRENCHEVY's Avatar
actually I was wondering on my 1995 tahoe 2 door 4wd , is it easy to remove the crankcase and install a longer driveshaft ? cause anyway since i replace the rear diff with a 3.73 posi and remove the front driveshaft and half shaft to front wheels , my crankcase is use less , so what I need is a support for the tranny from the cross member since the crank case is supporting it . is there any bracket that fit on the cross member to support directly the tranny ?
Old Jun 30, 2010 | 9:28 PM
  #14
arthurarinstar's Avatar
any tricks and time saving ideas for swapping out transfer cases in a 95 tahoe 4x4, with automatic trans, and floor shifter?
Old Dec 11, 2010 | 2:37 PM
  #15
Rubele's Avatar
Originally Posted by transguy37
Hello,
There is a lockring the breaks right in the little tailhousing on the back. This lockring holds the main shaft in place, when it breaks the shaft will move with motion. All the gears and synchros are on the main shaft and lets the gear it the slider ring and grind. They make a fix for it so it will never do it again. If you are interested in checking or fixing it, let me know and I can tell you how step by step.
Hey Trans guy do you have the step by step on how to replace this snapring? if so could you send. I think I have this problem. Thanks
Old Dec 11, 2010 | 3:13 PM
  #16
Welcome to the forum.
Since that post is almost two years old, you may not get a reply from him.
Old Dec 12, 2010 | 7:11 AM
  #17
Yes, please send it and I'll copy and paste it and see if I can do it myself:-)
Old Sep 27, 2011 | 4:12 AM
  #18
tgmg2's Avatar
Hello,
I have the same problem ON MY 95 SUBURBAN it breaks once a year going into the shop today, part cost $7 bucks and about $100 to have it done I WOULD LOVE FOR YOU TO GIVE ME A STEP BY STEP ON HOW TO FIX IT....THANKS
Old Jun 29, 2015 | 3:10 PM
  #19
Kalaka's Avatar
Default Transfer case
Hello, can u tell me how to do it please
Old Jun 3, 2016 | 7:28 PM
  #20
phil forrest's Avatar
New User
Awaiting E-mail Confirmation
Hello,
Please send how to do for me 95 2500suburban4x4 to Phil at philjforrest40 @gmail
