96 burb 2wd negative camber problem
Old Nov 22, 2010 | 6:33 PM
gmarcos74's Avatar
Default 96 burb 2wd negative camber problem
Hi, I have a 96 suburban 2wd, I just finished installing a 4" Spindle kit from rough country in the front ( it originally had 2" coil spacers intalled) and a 4.5" block set in the back. When I finished the install I noticed allot of negative camber on my front wheels is this due to worn out upper ball joints ( I replaced both lower joints) or the shock being too short? If it helps when I drive around it feels like there is no suspension travel at all!!! Please help!!
Old Nov 30, 2010 | 5:24 PM
wetz19's Avatar
When messing around with lifts and such with trucks, depending on a lift in the front or rear will set off your camber negative or positive. Some manufactures do develop cars with a slight negative camber because, the road is crowned. It isn't fully flat so they negative the camber in order to get a full on grip with the road. Roads are crowned for water run off.
carlosm180
Aug 23, 2014 8:42 AM
vwwebb
Apr 6, 2011 1:37 PM
vwwebb
Jan 2, 2011 11:24 PM
clearcreek
Jan 2, 2011 9:34 AM
caprice-classic 85
Jun 27, 2010 8:29 PM
