97 Burb What to repair/replace next???
Old Sep 6, 2013 | 10:02 AM
Mad_Max's Avatar
Default 97 Burb What to repair/replace next???
So I bought my used beast from an old country couple.
I got swindled, my own fault, moving on past that.
Repairs so far:
Alternator
Battery
Driver's door hinge pins replaced
Moog Upper and Lower Ball Joints (both sides)
Outer tie rod ends (both sides)
Moog U joints
Front rotors turned
Brake pads
Serpentine Belt and tensioner
Plugs and wires
Remianing known issues:
A/C compressor leaks (no idea how long since system has worked)
rear drivers power window doesn't work
rear passenger door stuck locked shut (lock rod disconnected from everything laying loose in bottom of door)
front doors roller pins need replacing
various body panels loose
headlights even after many restoration attempts, drivers side spotlight looking, passenger side not very visible on the road
suspect most of suspension could use replacing, but ride isn't bad
Any suggestions or thoughts would be greatly appreciated...
clicknathan
Jun 4, 2013 2:13 PM
mighty
Apr 24, 2010 4:11 PM
Familymanof5
Mar 30, 2008 4:52 PM
Sea Dub
Uplander
Jan 26, 2006 5:00 PM
Sea Dub
Uplander
