Old Jul 22, 2015, 10:34 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
97 suburban, no rear braking
Old Apr 14, 2011 | 6:42 AM
pilleway's Avatar
Default 97 suburban, no rear braking
Good morning to all! Thanks in advance for any help and or reccomendations.
I received a 1997 suburban with no braking in the rear! I bleed the rear and had very little fluid comming out, the owner says that the main brake cylinder was replaced and he was informed that the ABS Valve body needed to be replaced.
Found on RR wheel that the cylinder was leaking and I had replaced it.
After all with a Tech II, did the function test and no DTC's are stored, Red brake light (@ cluster) is allways on, and rear brakes do not brake, and brake pedal goes close to the floor.
Talking to the owner mentioned that some time a go when checking levels someone poor hydraulic steering fluid in to the brake reservoar and started to have braking problems, when he knew about it he took it to a shop to have all the brake fluid replaced, but problems started, finally he talk to me and I told him I will look in to the vehicle, but problem does not solve.
Any reccomendation or commet will be appreciated.
Have a nice day.
Old Apr 14, 2011 | 10:44 AM
nauticstar87's Avatar
if there not bleeding down well im noot sure why that is. It's possible the shoes aren't contacting the drums and may need to be adjusted or replace. Either way isn't hard to do.
Old Apr 14, 2011 | 5:11 PM
pilleway's Avatar
Nauticstar, thanks for the reply, the trick was to do the function test along with the bleeding did about 4 times each, after doing it I got rear braking.
Thanks!
kimoscout
Nov 25, 2014 11:13 PM
aubiexx
Aug 26, 2013 11:03 AM
Lateral72
Sep 7, 2012 9:57 AM
Treenap
Sep 24, 2007 8:26 AM
sixstringer
Feb 2, 2007 2:16 AM
