97 Tahoe A/C inop
Old Aug 8, 2025 | 12:01 AM
LarryE's Avatar
Default 97 Tahoe A/C inop
My compressor clutch is not activating when I turn the AC on. I hooked up a couple of jumper wires to the female plug on the compressor and it activates normally. I put a volt meter on the male connector plug pins and it is not getting power. I switched the AC relay with the starter relay and still no worky. Both fuses for the AC in the left inside fuse panel are OK. The blower fan works on all 4 speeds. When I press the round AC button on the AC control panel the yellow "ON" light comes on but the AC compressor isn't coming on. Those are the details. Any help is appreciated. Right now I'm betting on the AC switch on the AC panel.
Old Oct 6, 2025 | 8:51 AM
Jack Styer's Avatar
Default A/C issue
I had what I believe to be a similar issue. I replaced the high pressure switch on the compressor. The unit now functions as designed. Hope this helps.
Old Oct 7, 2025 | 7:55 AM
Cusser's Avatar
Have a shop check the refrigerant level, one needs special equipment for this. Low refrigerant can prevent compressor from getting power, to prevent damage.
Old Oct 7, 2025 | 9:45 AM
Rednucleus's Avatar
IMO if you don't know about HVAC it should be left to someone that does - I do alot of backyard wrenchin but A/C is hands off for me!
mikecallery
Apr 4, 2025 9:42 AM
Zach
Aug 7, 2011 7:29 PM
vit
Nov 11, 2008 5:43 PM
bern10
Nov 15, 2006 9:07 PM
deveng
Sonic (Aveo)
May 14, 2006 10:56 AM
