98 CHEVY TAHOE NO POWER
Old May 8, 2007 | 1:30 PM
Bear's Avatar
Default 98 CHEVY TAHOE NO POWER
Got in the car this morning, turned the key......nada. No power at all anywhere in the vehicle. Voltage across the battery still checks good. Truck is 98 Tahoe. Recommendations as to the 1st place to start troubleshooting would be appreciated.......
Thanks in advance!
Old May 8, 2007 | 1:38 PM
engine2's Avatar
Default RE: 98 CHEVY TAHOE NO POWER
Welcome to Chevroletforum.com!!!
I would first check to make sure all your battery connections are solid and clean.
Good Luck.
Old May 8, 2007 | 2:04 PM
sm3earl's Avatar
If your cables are good then you might want to check the soloniod.
Old May 8, 2007 | 2:40 PM
jmcash's Avatar
I had the same problem with my 99 tahoe...I put new bolts on the connectors ($3-$4 at auto parts store) and cleaned of the cables really good. Hadn't had any problems since.
Old May 8, 2007 | 6:10 PM
e's Avatar
e
fuseable link?
Old May 8, 2007 | 9:26 PM
DropsOfJupiter's Avatar
Better check the Battery Water, maybe your Battery Dried up or better get a maintenance check-up.
Tony_V.
Mar 23, 2014 10:10 PM
mitchell03
Feb 22, 2008 6:48 PM
Blazer311
K5 Blazer
Jul 26, 2007 6:53 PM
ToyHauler
Nov 1, 2006 10:12 PM
