98 Tahoe fan removal
Old Apr 11, 2006 | 5:03 PM
chris7584's Avatar
Default 98 Tahoe fan removal
Hello I have a 98 tahoe with a 5.7. I am trying to remove the fan to get to the waterpump with no luck. I have the manual and it states you can just remove the four bolts that connect the pulley to the pump. I have done this but the fan will still not come off. Any help would be greatly appreciated.
Thank you
Chris Woodruff
Old Apr 12, 2006 | 4:31 PM
Dondobe's Avatar
Default RE: 98 Tahoe fan removal
Chris7584, You need to remove the fan clutch first. I left my belt on until I got the fan nut loose. You'll see the shaft has a hex shape, It unscrews from the water pump. Good Luck, Dondobe
Old Apr 13, 2006 | 1:06 AM
viperjuice's Avatar
yeah you gots to unscrew that big fan clutch nut. it unscrews couter clock wise like any other nut. it's a pain but you can use a long screw driver on the bolts to jam the water pump and then a big adjustable or channel locks on the nut to brake it loose. make sure you put it back on snug later on
pdrayton
10
May 5, 2024 2:27 PM
pdrayton
May 29, 2013 7:55 PM
SweetEmotion
Apr 27, 2012 8:35 PM
TahoeMatt
Mar 2, 2009 3:12 AM
jimbo
Apr 23, 2006 7:27 PM
