98 Tahoe slow to accelerate. Please help
Old Nov 25, 2012 | 7:37 PM
Carrigerddd's Avatar
Default 98 Tahoe slow to accelerate. Please help
1998 Chev Tahoe 150,000miles
Check engine light isn't on solid now, but was on and off again for months . A new symptom is my engine is "cutting" out during hard acceleration, but if I gently accelerate, "cutting" out is not as pronounced. . And the final symptom... I have a new fuel filter
Ideas???
I've heard of similar problems on Chevy trucks involving a broken main ground cable.
Where is the ground cable? I thought it grounded the battery? Why would that cause a lack in acceleration? Is it expensive to fix? How do you fix it?
All thoughts are welcome. Thank you
Old Nov 26, 2012 | 4:45 AM
Jeff Collision's Avatar
Poor acceleration is often a symptom of engine hesitation. Engine hesitation has many possible causes, ranging from a simple dirty air filter to a serious transmission problem. If your car's air filter is plugged, it prevents the proper amount of air getting to the engine, which could cause engine hesitation. The air filter is simple to check, since it's usually under the hood. Similarly, a clogged fuel filter doesn't allow adequate fuel pressure into your car's fuel injection system. Blowing air through the fuel filter will tell you if the filter is clogged. Your engine may be fine but if the power isn't effectively getting to your wheels, you may have a transmission problem. Such a problem could cause acceleration issues when the transmission slips, because it causes the car to lose the power the engine just generated, while the transmission would normally transfer the power to the rest of the car.
Old Nov 26, 2012 | 5:27 AM
shamrock246's Avatar
Have you had the codes pulled? Autozone will do it for free
LuckyinKentucky
Mar 10, 2022 1:08 AM
pos95suburban
Dec 26, 2011 9:28 PM
adamlanders
May 7, 2010 3:21 PM
abenites
Jan 23, 2010 11:56 PM
shadowbunny
Jun 18, 2007 3:46 PM
