99 Chevy Suburban 4wd Button doesn't work
I have a 1999 Chevy suburban with 110K miles and the 4wd does not work. Here is the problem.
The 2wd and 4wd buttons do not light up and pressing the buttons does nothing. any ideas of how to get the 4wd working? I checked the fuse on the panel inside the dash and its fine.
ne1 (November 6th, 2022)
famousmomof4 Welcome to the forum,
If you have not already, try re-seating the connector to the buttons, they might just be loose....fully disconnect and reconnect it, there may also be a relay in the circuit, might check the under hood relays as well.
Thanks so much, we ended up changing the actuator only to find out that it still didn't work. Then my husband began web searching the issue on bing and found out there are 2 fuses for the 4wd .we changed out fuse #24 but didn't know to check Fuse #2 which was blown. So we put the old actuator back on and it all works great :-)
When we put a new fuse in #2 it worked, then popped after a few seconds( this was with the new actuator).. So we put another fuse in and now its been 3 days and it all is still working great.
If it happens again, I might have to look into it more.
Helped me get unstuck
