99 Suburban with a 454 bogs under throttle
99 Suburban 2500 with a 454 bogs down bad while under load while giving it some throttle. It has a strong air sucking sound while it does this. I hooked up a fuel pressure gauge and here are the readings.
Truck cold: ignition on truck not running 50psi and drops down to 22 in 5 minutes
Truck cold: Running at 47psi
Truck cold: 2000 rpms at 47psi
Truck hot: 47psi
No matter what rpm when hot or cold, it stays at 47psi. So i'm thinking its either the fuel pump or the pressure regulator. What do you guys think?
Truck hot: 47psi
New twist to the problem. I just discovered a puddle of rusty water under the truck coming from the water pump. I looked in the radiator to discover that it is quite low on fluid. So the next question is would low coolant cause the bogging? I was doing some reading on the coolant sensor and the entire engine performance is based on what that little sensor tells it.
dslemaire
Aug 23, 2018 9:46 PM
jamesharlan
Feb 24, 2014 7:13 PM
rocky2013162
Oct 19, 2013 10:39 PM
mikeshere443
Mar 29, 2010 9:17 PM
