99 suburban ,,how to adjust rear brakes?
Old Jun 28, 2014 | 10:12 PM
SOLOLUCKY's Avatar
Default 99 suburban ,,how to adjust rear brakes?
SO I did new rear drum brakes on my 99 suburban.
My question is simple...how do i adjust them?
Old school way was to back up several times and they adjusted, does that still apply or do they adjust under normal driving?
Old Jun 29, 2014 | 9:39 AM
Using the parking brake is how they are adjusted...Regular use of the parking brake will keep them adjusted..
Old Jun 30, 2014 | 12:35 PM
SOLOLUCKY's Avatar
Woud it be worth while taking the wheels and drums off and setting it up "close" manually or will they adjust pretty quick simply werking the Ebrake while sitting in the driveway? ?
Old Jun 30, 2014 | 2:13 PM
Sure that would work, but if you have the knock out port just remove the rubber plug and adjust with a flat blade screw driver...
Mille Racer 69
Dec 8, 2010 8:26 PM
92Stepside
Jun 13, 2009 12:45 AM
drb61
Feb 13, 2008 10:56 PM
TahoeHighlander
Jul 18, 2007 10:33 AM
ironcy
Apr 25, 2007 4:21 PM
