99 Suburban low voltage, engine loses power
Old Nov 1, 2013 | 10:41 AM
David Bailey's Avatar
Default 99 Suburban low voltage, engine loses power
I have a 99 suburban, a couple of weeks ago I got in and noticed the gauge showed lower than normal voltage. When I turned the AC on it dropped a bit further and the engine power dropped off dramatically. The next day I got in and the battery (4 months old), was completely drained.
Time for a new alt?
Old Nov 1, 2013 | 11:06 AM
Check to see if your alternator is charging? Sounds like you were running on the battery for a while till went dead.
Old Nov 1, 2013 | 1:03 PM
Time for a new alt?
Welcome to the forum...
Sounds like an alternator problem to me....once its replaced you might want to put the battery on a charger for several hours or over night...its possible for a battery not to recover from a hard draining just fyi...
Old Nov 1, 2013 | 2:32 PM
Most auto parts stores will check your alternator and battery system for free.
R6 Tech 413
Nov 22, 2012 5:04 PM
CHEVYOK
Nov 29, 2010 4:07 AM
byronrk
Sep 12, 2008 3:13 AM
brautig
Dec 12, 2006 8:01 PM
