99 suburban no heat
Old Dec 25, 2022 | 3:34 PM
  #21
Wavelength's Avatar
Talking No heat
Originally Posted by garimus
i have a 99 gmc suburban k15004wd that has no passenger compartment heat. The airflow director works great. air blows on floor/defrost/vents with no problem. The problem I have is that it never gets HOT. The A/C works great. I just need heat. Is there a seperate temp control "door" or acttuator that may be stuck? The heat doesn't wrk in the back either, but they "broke" about 8 months apart. front heat worked fine for a while, but now i get nothing but cold air. Heater hoses seem to indicate water flow all the way to firewall as they get hot, so i don't think its a water flow issue... but..
Any ideas? I came out late from work last night and my 5 year old was snuggled up to his mom because they were sol cold waiting on me.! Help!
I had a similar problem with my Astro van. Heat was on full and only coming from defrost. It was the vacuum hose from the engine to the vacuum reservoir. I guess default position is defrost on. Vacuum is needed from the reservoir to change positions. It wouldn't hurt to just change this hose. Also, if coolant gets below takeoff hose from engine their will be no heat at all and engine may or may not run a little hot. Good luck. Cheers. Wavelength.
Chevmann92
Jan 3, 2014 2:03 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
