99 suburban stutters going up hill
Old Dec 4, 2011 | 6:30 AM
tommyxj2000's Avatar
Default 99 suburban stutters going up hill
hey guys, i have a 99 suburban k1500 with 236,000 miles...every now and after driving all day i kind stutters when i'm going up hill kind of like its misfiring, the truck shifts fine so i dont think its the tranny, i know i'm a little over due for a tune-up which could be the cause but if not what else should i check after i do it if still does it...what i did to it so far was have the intake gasket changed because it leaking antifreeze from the top end and it would threw a code for the cat a couple of time before i changed the gasket....since it was repaired, no codes...thanks in advance
Old Dec 4, 2011 | 7:13 AM
adam86107's Avatar
If you know you're overdue for a tune up I think I would just go ahead and start there seeing how it needs to be done anyway.
Old Dec 4, 2011 | 7:33 AM
shamrock246's Avatar
spend the money on AC/DELCO stuff i had cap and rotor problems with what looked to be autozone stuff
www.summitracing.com
www.oehq.com
Old Dec 5, 2011 | 2:49 AM
the only thing i go autozone for is oil and coolant, other than that i hate that store with a passion...as soon as some money frees up, i will do the tune-up
Old Dec 9, 2011 | 10:40 AM
While you're in there, check the fuel pressure.
Old Dec 9, 2011 | 1:55 PM
SabrToothSqrl's Avatar
Default well
if you hit 280,000 you will have matched the miles on my '95 when I sold it.
good luck!
cfrazier34
1988 - 1998 (GMT400)
12
Jul 2, 2024 5:26 PM
THE_CARNEYS
Aug 21, 2015 1:02 AM
ikeyboy
Jun 27, 2012 8:17 PM
kanyons
16
May 17, 2011 11:16 AM
live4perfection
May 6, 2008 10:59 AM
