99 Tahoe - 4x4 Push Button Problem
Old Feb 9, 2008 | 7:22 PM
wreckless123's Avatar
Default 99 Tahoe - 4x4 Push Button Problem
Anyone had any problems with their switch for their push button 4x4? Today I had it in auto 4x4 on the back roads, when I got to pavement I went to 2wd with no problem. Pulled into the gas station and noticed none of the lights were on? I tried to push 2wd and it did nothing. Then the light came back on but on auto 4x4. Finally it let me put it back in 2wd and was fine the rest of the day. Is this a common problem? Thanks
Old Feb 9, 2008 | 10:33 PM
Slammed's Avatar
Default RE: 99 Tahoe - 4x4 Push Button Problem
you have to put it in neutral before you change it from 4x4 to 2 ect also the light wont allways stay lit but its ok
Old Feb 9, 2008 | 11:14 PM
aztecf's Avatar
This is a common problem, the solder joints crack in the switch. You need to take the switch apart and resolder the connections.
Jeff
Old Feb 10, 2008 | 11:06 AM
ORIGINAL: Slammed
No you dont, thats the whole point of push button..
Jeff
Thanks Jeff, I had a feeling I was going to hear that. Are the joints obvious when I take the switch out?
Old Aug 12, 2008 | 8:41 PM
haulinoats's Avatar
I know this post is a bit old, but thanks for the information on the joints.
If you read your owners manual, it says you must put in nutural to switch out of 4wd low fyi.
jla74
Oct 25, 2021 12:54 PM
dmm26
Nov 30, 2010 1:47 PM
jmonty
Nov 17, 2010 5:35 PM
cqlink
Sep 17, 2010 11:38 AM
buick48
Dec 28, 2007 6:22 PM
