99 Tahoe cylinder misfire
Old Aug 20, 2014 | 8:55 AM
Shmoe's Avatar
Default 99 Tahoe cylinder misfire
I recently acquired a 99 Tahoe. I don't know much of the history as its hard to track down its previous owner. To start off here's a list of some problems with it.
- very rough idle, makes the vehicle shake
- throwing a 305 code (misfire on cylinder 5)
- a rattling noise when I get on the throttle, it nearly stops at coasting speeds and deceleration. Doesn't sound like a knock.
- gurgling noise when it sits at an idle
- very thin white smoke (does not smell like burning oil) when I throttle it up in neutral.
I've been told that a couple lifting rods have been replaced and some of the plugs and wires. I don't know if they all have or not. I don't know if the distributor or its cap was replaced either. Those are the first things I would check if it wasn't making a gurgling noise and rattling when I get on the throttle.
I cannot find any coolant leaks but it does have oil on the starter and oil pan.
Anyway first things first, I want to find out what's causing the misfire. Thanks for the help and sorry if this is a repeat of another post.
Old Aug 20, 2014 | 9:46 AM
Shmoe's Avatar
Default fuel
Could it be the fuel mixture getting to that cylinder?
TahoeMatt
11
Feb 6, 2012 7:15 PM
kitonga
Jun 1, 2010 7:42 AM
adambraap
Feb 16, 2007 7:49 PM
adambraap
Jan 28, 2007 9:58 PM
akimber
14
Aug 22, 2006 11:45 AM
