99 tahoe won’t turn over
Old Jan 10, 2022 | 11:21 AM
claflinshane's Avatar
Default 99 tahoe won’t turn over
started my 99 tahoe about 5am started fine and drove it the day before multiple times and it was starting fine than after i started it at 5 am cause it was so cold outside it sat till about 2:30 pm now it wont turn over anymore tried jumping it since i thought might be battery but nothing it doesn’t even try to do anything
Old Jan 14, 2022 | 6:30 PM
Welcome to the forum. I'm moving your post to the Tahoe section of the Forum where it will get more views.
Old Jan 15, 2022 | 8:28 AM
Cusser's Avatar
Assuming that the battery cables and battery terminals are clean and tight: (1) Post voltage across the battery terminals. (2) Then measure/post that same voltage across the battery terminals while the key is turned to the "Start" position for 5 seconds.
This would apply to any vehicle....No DC voltmeter/multimeter??? GET ONE, or have it towed to a shop.
Old Jan 15, 2022 | 9:21 AM
repairman54's Avatar
My '99 Yukon. same drivetrain, the braided connector from the starter motor to its solenoid corroded away on me causing a no start. Salt zone driving got to it.
Old Jan 15, 2022 | 9:45 AM
Rednucleus's Avatar
Drove my 93 Sub to the hardware store, time to go home and nothing turning the key. Found a wire had broken off the starter.
Old Jan 15, 2022 | 9:52 AM
Cusser's Avatar
Mid-2021, my own 1988 Mazda truck was having similar intermittent no-cranking situation, otherwise cranked started fine. I TESTED its clutch pedal safety switch (fine) and the ignition switch (fine), cleaned the battery terminals again, even swapped out my 34-month old battery for a brand-new one as it had 2-months remaining on replacement warranty. None of these fixed the intermittent cranking issues.
The fix? I took off the negative cable attachments to the engine, the body, and frame and cleaned everything up with wire wheel/drill, steel wool, etc., and reconnected. All fixed, 6 months now and no more failure to crank/start.
Toni smith
Jun 2, 2021 11:08 PM
seavolt88
Apr 26, 2018 8:13 PM
Xyz
Oct 19, 2017 8:53 AM
Darkarcher
Jun 30, 2014 12:51 PM
aabner75
Feb 25, 2014 4:03 PM
