ABS Code
Old Oct 10, 2013 | 12:04 PM
cbe295's Avatar
Default ABS Code
I have a 2001 Suburban with a C0265 Code which is Electronic Brake Control Module Relay Circuit. It also has the auto 4wd which means when the abs light is on the 4wd won't engage. I was wondering if there is anything I can do to get it to work. Thanks.
Old Oct 10, 2013 | 8:01 PM
Urban Suburban's Avatar
I also have an 01 suburban with the same abs code. Your best bet is to no longer use "auto 4x4" and push the "4x4" button when you need 4 wheel drive. The only way to fix this is to have your ebcm (electronic brake control module) replaced. It is located on top of the abs pump under the truck, the drivers side frame near the drivers door
mnm567
Feb 14, 2016 6:18 PM
guvner
Aug 1, 2010 9:21 PM
terry_g
Jun 24, 2010 8:57 AM
fmd63
Mar 2, 2009 3:29 PM
mnm567
Oct 12, 2006 12:41 AM
