AC Help needed
Old Dec 10, 2011 | 7:15 PM
2000dreambird's Avatar
Default AC Help needed
hey guys i'm new to this site.. i have a 00 hoe, new body style and i'm having a problem with the AC. sometimes it works sometimes it doesn't. if you push the button to turn the AC on it will flash a few times and go back off. but then other days it works no problem and when it does work its ICE cold..
Old Dec 11, 2011 | 11:33 PM
NMguy's Avatar
This could be the Relay it's located near your main electrical box under the hood. some times it's clipped on the box sometimes it's near by the box. sounds like a bad relay or a connection on the relay. sound like the AC compressor works ok. This is an electrical switch problem, replace the relay. check the electrical connections and conductors ( wires ) at the AC compressor also make sure that connection is tight.
Old Dec 12, 2011 | 3:40 PM
Thanks for the info, i'll let you know if this fixes the problem.
RickG
Nov 9, 2006 7:35 AM
86Caprice
Oct 10, 2006 8:31 PM
cbmontgo
May 29, 2006 1:23 PM
st3ph3n
May 22, 2006 11:01 AM
Soulcrusher
Feb 25, 2006 9:21 AM
