Access to fuses
Old Jan 4, 2011 | 8:27 PM
Moveqik's Avatar
Default Access to fuses
I'll introduce myself here with a dumb question.....how do you access the fuses for the stereo in a 2007 Suburban? I can access the fuses under the hood and the ones on the far left side of the dash but not the ones I need! The owners manual says they are located under the instrument panel to the left of the steering column. I can't find any panels under there to pop off that would give me access to fuses.
Any help is appreciated!
Thanks in advance.
Old Jan 5, 2011 | 9:26 PM
Welcome to the forum..
To the best of my knowledge there is only 2 fuse panels, the left of the IP and the under the hood....
Old Jan 5, 2011 | 9:28 PM
Here is a fuse location other then the 2 listed
DVD Fuse (Headrest DVD System)
Part of cable #9, in the center console near the DVD control module
Old Jan 5, 2011 | 9:34 PM
Here is one more for the Radio but is listed as being in the under hood location #41
41
RDO Fuse
15A
Analog Clock (Z75), Digital Radio Receiver (U2K), Radio, Rear Seat Audio (RSA) Controller (UK6)
Old Jan 6, 2011 | 10:33 AM
damone's Avatar
I have a panel to the left of the column. It has a long plastic hex bolt that holds it on. I could remove this panel/bolt with my fingers.
I saw mostly large black boxes (relays?). Didn't see any fuses.
Old Jan 7, 2011 | 10:46 AM
damone's Avatar
Here is a link that shows the panel. Dont think the story helps, but the pic is good.
Old Jan 7, 2011 | 4:56 PM
Official GM Rep
Movequik, I checked through your owners manual and found that there are only two fuse blocks in your vehicle. The one off of the Instrument Panel and the one in the engine compartment. It sounds like you've already found both of these blocks. Hopefully the information already given here is able to help you.
Jeff Morris, Chevrolet Customer Service
Conehead
Mar 11, 2018 11:03 PM
2silverados
13
May 8, 2008 7:46 AM
Kevin8520
Aug 31, 2007 3:32 PM
rphtahoe
Apr 21, 2007 5:55 PM
aeroclimb
Dec 3, 2006 9:22 PM
