Aftermarket modification numbers? HP/TQ/MPG
Old Oct 9, 2006 | 11:44 PM
DarkOne's Avatar
Default Aftermarket modification numbers? HP/TQ/MPG
Just wondering if anyone has any hp/tq/mpg numbers after modifications? I purchased a Gtech SS, showed numbers for 0-60 @ 6.86 1/4mile @14.76. I don't think HP is right, since it read 502 and TQ at 571 ft/lbs. Did a reset on the MPG and showed an increase from what it used to be...gain of 2 mpg. Anyone else?
DarkOne.
Old Oct 10, 2006 | 1:41 AM
Default RE: Aftermarket modification numbers? HP/TQ/MPG
I got a G-Tech Pro also but haven't had time to set it up. It sounds like getting the initial mounting correct is key to getting accurate readings tho. I certainly would question Hp numbers higher than 320 w/o any mods. Those kind of readings (if accurate) should yield a better ET than 14.76. Will let you know what I get when I get it set up.
Old Oct 10, 2006 | 2:06 AM
ZX1100F1's Avatar
That must be the device that Dodge uses to come up with their erroneous HP numbers.
Old Oct 10, 2006 | 2:15 AM
Could be. Don't follow Dodge much. Hadn't heard that they were fooling with their numbers.
Old Oct 10, 2006 | 3:13 AM
DarkOne's Avatar
Yeah I have to reset the settings b/c of the G's are off once in awhile. I did however get one reading before the exhaust was put on, the HP was 310 and the TQ was at 390 ft/lbs. I thought that was pretty close to what I should get. I am still waiting to get on a 1/4 mile stretch (flat) to get a more accurate reading. Those readings earlier were from a stand still, but making a right turn (from a stop sign) then going up hill, so I am guessing the G's factor into the equation. Not sure though, that is when I had those readings this evening. Shark let me know what you get. The Gtech is a neat gadget, but would like to get the truck on a dyno along with the GTECH and see if they match.
DarkOne.
Old Oct 10, 2006 | 11:34 PM
biglg's Avatar
What is this Gtech?
Has anyone purchased the Superchips 2815 or a cold air intake kit for their 2007? What do you think?
Old Oct 11, 2006 | 12:06 AM
DarkOne's Avatar
Biglg,
Go to Gtech Pro website. I think it is www.gtechpro.com Pretty neat gadget. I have it plugged into my tahoe. I have the Gtech Pro SS. Take a look. I think someone has the superchips flashpaq (friscokid) maybe. I hope to get one at the end of the month when I get some cash. By the way I do have the air raid CAI. I reset my MPG and looks like I increased 2 MPG when I don't mash on the pedal, of course. Even then it doesn't go down to what it used to be.
Old Oct 11, 2006 | 4:02 PM
biglg's Avatar
Dark One,
Thanks for the reply. I want to get the superchips also, it was the best mod I put on my hemi ram truck. I have seen them on ebay for around $365 with best offer option.
As for the CAI I think i will go with the volant to keep the filter enclosed for sound. I know some of you have said that aftermarket open air CAI on this 07 tahoe doesnt make any noise, however every open air filter i have had makes all kind of noise when accelerating! Thanks.
Old Oct 11, 2006 | 4:03 PM
biglg's Avatar
Dark One,
Old Oct 11, 2006 | 4:17 PM
fyrcaptain's Avatar
You got the right WEIGHT programmed in?
