Air Conditioning Valve Cores
On a '98 Tahoe are the A/C high and low port valve cores replaceable or do you have to replace the hard line? I see that Rockauto sells a kit so I assume that they are but I thought I should check before spending the money on them.
The reason I question if they are is that my '03 Dodge Ram has the valve set into the hard line.
Jeff
Jeff
I'm not sure I understand you exactly about the term "they bolt off of the line with a special socket".
From looking at pictures of parts on Rockauto's website I can see where the high side port could be removed. I was hoping to do it without losing the charge though.
I have a valve core removal tool. I just can't figure out which valve cores I need from Rockauto's site.
Jeff
Jeff
MD - Is that true for both high and low side connectors? I ask because I have already ordered the high side connector from Rockauto but they do not carry the low side connector that I can tell.
Thank you for your help.
Jeff
Jeff
oehq.com
Mar 25, 2010 4:10 PM
