Airbag sensor
Old Feb 23, 2018 | 7:47 AM
  #11
A few codes I found that list possible causes, you may need to dig a little deeper for the code level..
DTC B0081 0F: Passenger Presence System Erratic
DTC B0081 3A: Passenger Presence System Incorrect Component Installed
DTC B0081 4B: Passenger Presence System Calibration Not Learned
DTC B0081 5A: Passenger Presence System Plausibility Failure
DTC B0081 39: Passenger Presence System Internal Electronic Failure
DTC B0081 71: Passenger Presence System Invalid Serial Data Received
Last edited by in2pro; Feb 24, 2018 at 9:15 AM. Reason: updated for clarity, codes listed are diagnostic possibilities not actual users
Old Feb 23, 2018 | 1:22 PM
  #12
Miami Son's Avatar
Those codes sound like the airbag was not replaced properly.
Old Feb 23, 2018 | 9:08 PM
  #13
no recall for this cause its not injuring people...unlike the tekata airbag recalls.
Old Feb 24, 2018 | 9:16 AM
  #14
the passenger presence system is about seat detection not the airbag itself. Checking the restraint system wiring under the seat would be a good start. they had issues with the connectors to the seats on the encalves; which resulted in cutting out the connectors and hardwiring it....which meant it would be a pita if you had to remove the seat out of the vehicle.
