Airbag service light and message
Old Oct 22, 2010 | 4:50 PM
Mjhmjh158's Avatar
Default Airbag service light and message
I have 2009 tahoe LT and all of a sudden after I started the engine, I saw the sign on the front board. Any one can advice what is best thing to do?
Old Oct 22, 2010 | 4:58 PM
you may still have warrenty left and should have it inspected by a qualified Technician but here is what I found that may be of some insight...
2009 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual |
Document ID: 1892094
#07-09-41-002: Air Bag Light On, DTC B0081 Set (Clear
DTC Using Specific Procedure) - (Jan 29, 2007)
Condition
Some customers may comment on the airbag light being illuminated. Upon investigation, the
technician may find DTC B0081 with symptom code 0F, 3A, 39 or 71 set.
Correction
The Sensing and Diagnostic Module (SDM) should NOT be replaced when DTC B0081 sets. The SDM
sets DTC B0081 only to report that there is no communication with the Passenger Presence System
(PPS) module or that the PPS module has reported a fault. It is important that when the B0081
fault is reported by the SDM, the DTCs from the PPS be retrieved and addressed first per the
procedure below. After the PPS module DTCs have been addressed, turn the ignition off, open the
driver's door, and wait 40 seconds for the PPS module to go to sleep.
1. When DTC B0081 71 sets, inspect wiring and connections for a possible loss of
communication between the SDM and PPS module. Inspect front passenger seat connector to
the PPS module and seat connector to the seat harness. Do not replace the SDM module for a
DTC B0081 71 condition.
2. The SDM will set B0081 3A indicating that a wrong PPS module has been installed on the
vehicle. Verify the condition before replacing the known wrong PPS module with a correct
one. Use service information to reprogram and set up a new PPS module.
3. The SDM will set B0081 0F and B0081 39 indicating that the PPS module has reported a fault
to the SDM. Retrieve the DTCs from the PPS module and address those first.
4. The PPS may continue to send it has a fault to the SDM for the above conditions, though
there are no active faults reported by the PPS, until the steps in the note below are taken.
Important: DTC B0081 will not clear until the low speed bus goes to sleep. To clear DTC B0081,
turn the Ignition off, open the driver's door and wait 40 seconds for the PPS to go to sleep. Turn
the ignition to run and retrieve vehicle DTCs. If all the codes have been cleared from the PPS, DTC
B0081 in the SDM will not be active and only be in history.
Warranty Information
For vehicles repaired under warranty, use:
Subject: Air Bag Light On, DTC B0081 Set (Clear DTC Using Specific
Procedure)
Models: 2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
© 2010 General Motors Corporation. All rights reserved.
Document ID: 1892094 Page 1 of 2
Labor Operation Description Labor Time
C9709* Procedure to Clear DTC B0081 from SDM. 0.5 hr
* This is a unique labor operation number for bulletin use only. This number will not be
published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a
""do-it-yourselfer"". They are written to inform these technicians of
conditions that may occur on some vehicles, or to provide
information that could assist in the proper service of a vehicle.
Properly trained technicians have the equipment, tools, safety
instructions, and know-how to do a job properly and safely. If a
condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See your
GM dealer for information on whether your vehicle may benefit from
the information.
WE SUPPORT
VOLUNTARY
TECHNICIAN
CERTIFICATION
Document ID: 1892094 Page 2 of 2
Old Apr 4, 2016 | 5:42 PM
SabrToothSqrl's Avatar
Our 2009 Tahoe has this light and code... Good times.
So, it looks like I check the wiring under the passenger side?
It has B0081 and B0083
First row enter seatbelt load limiter deployment control
Second row left seatbelt load limiter deployment control. Sub fault.
Have people had luck fixing this?
Old Apr 7, 2016 | 1:41 PM
Goes to the dealer Wednesday...
Old Apr 7, 2016 | 10:49 PM
cleveland63b's Avatar
likely to be a connection issue but I don't recommend messing with airbag stuff unless you're knowledgable about the system
Old Apr 8, 2016 | 4:25 PM
Official GM Rep
Hello SabrToothSqrl,
Keep us posted on your dealership visit Wednesday. I read over the concerns that you've recently encountered with your Tahoe and want to apologize for any inconvenience caused. We're available via private message if additional assistance is needed.
Jasmine
Chevrolet Customer Care
Old Jun 19, 2024 | 8:41 PM
ggreen2007Tahoe's Avatar
I have a 2007 Tahoe LTZ. What you have to do is get a scanner/ ODM and see if you can read the code. The code will tell you which impact sensor is bad. Both sensors are under the radiator in the front of the Tahoe. Now, if you connect the ODM and it cannot communicate with the ECM, you will need to check two fuses. The Airbag ING 10 AMP fuse and the Airbag ING Batt 15A fuse. Mine was corroded so I had to clean the fuse housing and replaced the fuse. I hope this helps.
Typerod
Jun 19, 2024 8:34 PM
Jackson 63
Apr 29, 2014 7:41 PM
boychevy
Jul 30, 2013 2:21 AM
05chevy
Oct 6, 2012 7:56 AM
Davidc21a
Apr 3, 2012 9:06 PM
