Anyone know what 07 wheel offset is
Old Aug 11, 2006 | 9:45 PM
azsheriff's Avatar
Default Anyone know what 07 wheel offset is
Anyone know the wheel offset for the 07 Tahoe? Am trying to get some aftermarket wheels but being constantly told problem with offset and won't fit.
Old Aug 11, 2006 | 10:36 PM
deejayrock's Avatar
Default RE: Anyone know what 07 wheel offset is
azsheriff, I have also been looking around for the stock offset of the wheels and I beleive it is +30mm. Hope this helps, Thanks.
Old Aug 12, 2006 | 1:53 AM
azsheriff's Avatar
Thanks DJ
Old Aug 12, 2006 | 3:13 PM
EscalonJon's Avatar
I believe that you can just remove a wheel, lay a straightedge across the rear bead/lip of the rim, and measure from the straightedge to the hub mating surface.
Old Aug 14, 2006 | 12:37 AM
That's called back spacing. Offset is the distance between the mounting plane of the wheel and the centerline of the wheel and is expressed as positive or negative. If the centerline is to the outside of the mounting plane, I believe it is negative offset. Hope this helps.
Old Aug 14, 2006 | 8:57 PM
EscalonJon's Avatar
Mybad, 73, you're correct. I got my nomenclature screwed up. I'll think a bit more before I commit myself to looking foolish next time. lol...
Old Aug 14, 2006 | 9:46 PM
ZX1100F1's Avatar
The stock offset for the factory 2007 Tahoe wheels is +31mm
Old Oct 3, 2006 | 11:33 PM
ohmslaw 6's Avatar
Looking at a set of Centerline G2 wheels for my 2007 Tahoe will a 4.5" backspacing on a 10" x 17" wheel work?
plan on stuffing 33" tires under the SUV with a skyjacker 2" lift................. or 35" tires but waiting on more 3" lifts to come out besides Rancho. Any issues with Stabilitrac when lifting or lowering?
Old Oct 3, 2006 | 11:45 PM
biglg's Avatar
I was thinking the stock offset was +31 or +32. I know someone stated +31 so that is probably it.
You wan to find an offset around +30 for the best fitment.
You are correct, mos wheels will not have that offset, mos will be around +15 to +20.
Old May 10, 2007 | 12:07 AM
muzhik's Avatar
Sorry for bringing up an old topic, but I was wondering if anyone was able to put 24"s on they're 2007 avalanche/tahoe/suburban? I'm really looking into getting 24"s... but afraid that they will rub on turns, I know that I need +32mm offset... Any advice/suggestion, greatly appreciated..
-thx,
