Auto running board issue
Old Aug 27, 2020 | 6:37 PM
N2877's Avatar
Default Auto running board issue
New to the forum. I have an 09 Ltz suburban. The driver side running board makes a grinding noise when it trie to open. It doesn’t open. And the automatic rear hatch stopped opening and closing with the the push of the button. Is there an easy non dealer fix
Old Aug 28, 2020 | 7:46 AM
Welcome from Florida. Are you saying it makes a grinding noise when you try to open the door? If so the running board might be bent upwards. Check all your fuses first of all to see if that is the problem with the rear hatch.
Old Aug 28, 2020 | 9:13 AM
the running board motors can seized up.
does the rear hatch lift up if you help it. weak assist strut/s are the usual culprit. if you remove them and can compress then by hand they are nfg.
Old Aug 28, 2020 | 1:31 PM
N2877's Avatar
Thanks for the help
Old Aug 28, 2020 | 1:33 PM
N2877's Avatar
I will go up if i help it. It won’t go down automatically when I push the close button. I will check fuses
Old Aug 28, 2020 | 1:35 PM
N2877's Avatar
thank you for your help. When I open the door the running board tries to go down but all you hear is a nasty grinding. And it does the same when I close the door and the running board motor tries to retract the running board
Old Aug 29, 2020 | 8:49 AM
repairman54's Avatar
Nasty grinding may be that the motor assy. is bad.
My boards bind up and get slow or partial open then retract in the Northeast winters. TriFlow lube is the only thing I've found to keep my boards running smoother year round.
No sounds when the are binding. They will not work in sub zero weather.
bchambli
Apr 6, 2018 7:37 PM
Schoolcop
Jul 14, 2015 1:26 PM
mcdunnmt
Sep 16, 2014 7:08 PM
tjkusa
Sep 9, 2012 11:00 PM
DeFester
Sep 4, 2007 2:28 PM
