Autoride air pump runs too much
Old Aug 29, 2012 | 11:17 PM
DPLarson's Avatar
Default Autoride air pump runs too much
I have a '06 Suburban LTZ K1500 and lately I think the air pump for the air shocks is running too much. Typically I would hear it when first starting the engine for a short time then only hear it again if the load in the rear end changed. I tow a 21ft camper quite a bit and of course when hooked up to the trailer, the pump runs quite a bit longer but then stops and that is about all there usually is too it.
Lately, whether towing or not, it seems to run longer than usual before stopping and sometimes it will just start running again for a while.
I know some people are not a fan of this system but I am not into rock crawling, lifting or lowering and I would actually say typically this system works quite well and keeps our vehicle level whether empty, hauling, towing, whatever. I would like to know how to troubleshoot this system, other than disable something, pull fuses, etc. Any ideas?
Thanks so much.
Old Aug 30, 2012 | 8:57 PM
bigbake's Avatar
Thanks so much.
You have a leak somewhere in a line or shock. I would find it soon and see if you can save the pump before it burns itself out running to much.
Search back in the threads and a GM service rep posted a pretty good descrip of how to trouble shoot it.
BrandanDeMamp
Apr 8, 2014 7:22 PM
pamelacay
Aug 21, 2007 12:29 PM
EPJ
Nov 13, 2006 2:44 PM
