Autoride system?
I have a 2008 Suburban LT. No Autoride system.<O
</O
<O
></O
Can I install 1 with the correct shocks, or is it more complicated than that?
I would want to use the gm autoride pump, not an after market pump.
<O
> </O
Curt
</O
<O
></O
<O
> </O
>Curt
why do you want this? from all I have read they are more of a pain than worth (and expensive to repair). unless you want to haul a heavy load - if so I would add aftermarket air bags just to the rear to keep you level.
Be a lot easier and cheaper to install some air bags or air shocks that you can air up when you're hauling loads.
The OEM system shocks are very expensive and besides the compressor, you'd need the sensors and I'm not sure if your BCM could handle it.
