Aux Fuel Outlet or Standpipe for Espar Heater?
Old Nov 30, 2021 | 11:36 PM
raven108's Avatar
Default Aux Fuel Outlet or Standpipe for Espar Heater?
Hello everyone...I am installing an Espar Hydronic Water Heater (block heater) into my 2011 Suburban. I have been looking for, but haven't found if there is an Aux fuel tap or an accessory fuel outlet on the tank. Basically, I'm trying to figure out where to tap into the fuel system so I can supply my new block heater with combustion fuel. Might there be a place to tap into the fuel system that doesn't require me dropping the tank and tapping in my own standpipe? Any thoughts would be appreciated! Thanks!
Old Dec 1, 2021 | 6:55 AM
repairman54's Avatar
Nope, fuel system is pressurized on feed and return lines so leave them alone. You'll have to drop the tank and put an independent non pressurized line in for the heater. Those heaters are meant for big trucks not light duty trucks so no aux. fuel sources.
Is this Sub diesel? I hope so as I've never heard of a gasoline fired heater.
Old Dec 1, 2021 | 10:12 AM
raven108's Avatar
I thought as much. The heater I'm installing is made for light-duty trucks and cars. Here's a link (Eberspacher Hydronic S3 B5E
). They make 2 different versions diesel and gas. Thank you so much for confirming that I'll need to install a new standpipe. I was just hoping beyond hope not to need to drop the tank.
Harry in Ky
Sep 26, 2019 11:55 AM
Rick1970
Nova & Chevy II
Mar 5, 2016 4:17 PM
joelvr
Jan 9, 2012 5:02 PM
Sunup
Nov 2, 2011 6:06 PM
88BLAZER
K5 Blazer
Jan 25, 2007 4:32 PM
