Aux-port input in a 2002 Tahoe Z71?
Old Mar 2, 2010 | 2:36 AM
  #11
JoeALVES's Avatar
Default Thanks friedrich !
Thanks a lot for your response, but it seems they don't have adaptors for AC Delco brand !!! Sic !
Regards
Joe
Old Mar 2, 2010 | 7:03 PM
  #12
fredrich03's Avatar
Default Aux-port input in a 2002 Tahoe Z71?
Joe, They must not know Delco is an OEM radio.
Also pm sent.
Old Mar 3, 2010 | 9:24 PM
  #13
Are you sure the OEM radio is a Delco?
Old Mar 4, 2010 | 2:17 AM
  #14
JoeALVES's Avatar
Yes, Delco Electronics Model : 15071234 here is the pics
Old Mar 4, 2010 | 2:18 AM
  #15
JoeALVES's Avatar
Here the pics adresses :
http://yfrog.com/0yimg0607rcj
http://yfrog.com/ehimg0599dj
Thanks
Old Mar 6, 2010 | 12:42 AM
  #16
gmlover's Avatar
Try logjamelectronics. That's where I got my aux input from. I've had it going on 3 years now with no problems. Hope this reply helps.
Old Dec 12, 2011 | 9:59 PM
  #17
Igor.p's Avatar
Default AUX for my Chevy Tahoe 2004
Hi guys,
sorry for my english. I am from Czech rep. I am a sound mixer and was disapointed with listening music from my iPod via FM transmitter. I was looking for a better way. The headphones output from iPod gives a weak voltage that makes more noise when you are trying to push up the volume. But the dock connector gives almost 1 volt/0dB = almost line output. Means better noise ratio! So you need an RCA/dock cable.
I have found on the web sites, that I can buy an Aux reduction for my 6CD/radio: Precision Interface Electronics GM12-AUXv2, P.I.E. GM12-AUXv2 Auxiliary Interface GM
It is working well now, but You must make a proper wiring = put the right cable for constant + (cigaret lighter conection working good)
Than you must find the right position of the AUXv2 int. switch (put the switch on the position for the band button switch, or for the CD charger switch. For mine was working the band button switch.)
After few days the AUX stopped working, so I,ve reassamled it again and found out, that the switch dropped out because of vibrations off road driving. So i have put the switch button out and solder the contacts together for ever. From this moment the GM12-AUXv2 is working without any problem!
So good luck!
Igor
musulk
Jan 23, 2013 6:27 PM
kayster
Nov 20, 2010 2:50 PM
ELurie
Jan 23, 2010 5:09 PM
fyrcaptain
Sep 2, 2006 9:35 PM
