Auxiliary tranni cooler question
Hey, I have a in- radiator cooler, but when towing I went up to 211 on heat, and it's not even summer, it was 60 outside temp. Also, do u hook it up as a pre cooler before it enters the radiator or after it goes threw the radiator? Do I use the upper line or the lower line from the radiator?
deryll1,
Actually, it's been done both ways (in radiator & external). All lubrication is designed to operate best within a range of temperature, so, as old dog said, not too cool, but not too hot as well.
So, IF your vehicle was intended to be operated in like Desert/Hot climates, then it would be a good idea if the Cooler (little Radiator) was external. And if operated in colder climates, then it would be good if the Oil had a boost in temperature, shared the heat of the engine (via the Radiator Coolant).
Actually, it probably would be best for the Transmission, if it's Lubrication was controlled by a Thermostat, but the temperature range of Transmission Fluid has a sufficient operating range, where that would be an additional cost, and whose effectiveness would be questionable.
Other than the Manufacturer of the Vehicle's intent to ship the Vehicle to be sold/operated at a given Latitude, it would be hard to say just why one Manufacturer did it one way, and another, the other way.
So in your case, why not both...
Leave it running through the Radiator to accelerate warming it up, then, put a External Cooler on it, to make sure it didn't overheat. However, 211 deg isn't anything to worry about with Transmission Fluid. I'd be more worried about why your cooling system, didn't keep the Engine Coolant nearer to 195.
I did mine on my 2007, here is the thread... I recommend the factory one as it will come with everything you need and everything will fit properly.. no cutting, no clamping...
https://chevroletforum.com/forum/tah...install-35484/
I suspect it's connected before the cooler in the radiator to ensure that the fluid doesn't get too cold in the winter.
I remember on my '89 Dodge Caravan, they had to add a thermostat to the external cooler as the fluid would "slush" in really cold places like Minnesota.
So, I can see in a XXHot climate, where one may just separate the Transmission Oil completely away from the Radiator, using one or more Coolers. Therefore removing any heating contribution from the Cooling System.
Or, in just a relatively hot climate, where it may freeze occasionally, that one might put the Cooler before the Radiator. Therefore removing the major part of the heat, and, still having the ability to get it warm quickly.
Then, since most Transmission Fluid can operate quite well at 195 deg and more, I can't see why one would put a Cooler after the Radiator. Why heat it up, just to cool it down.
However, given the efficiency of most all Cooling Systems on vehicles now a days, IF one had a overheat problem while Towing, I'd seriously be looking at deficiencies in the Cooling System as I stated previously, before I considered an add-on Cooler.
PS: And in places like Minnesota, I definitely would support an "in radiator" capsule, to keep the Transmission Fluid's temperature up.
I live in Sacramento Cali, so we get freezing temps like maybe once in a while. But maybe I should flush my radiator first. But I drove it last year in the summer without towing it went to 198. So I guess I will consider hooking it up before it enters the radiator....
