Last edit by: IB Advertising
Browse all: Steering and Suspension
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Power Steering Pump
Backup camera problem
Hi all. My first thread and I'm asking for help. The backup camera on my 2007 LTZ is not working. When you put it in reverse, the screen comes on and is black. The little warning at the top is on but nothing else. I took it to the dealer and they said the module was bad. I replaced the module under the seat and that didn't fix it. Is there any other module to replace? Thanks for all responses.
Sometimes we need to go back to the basics.....even the most simple things are overlooked. This has happened so often that GM has release a bulletin on it.....see below
Subject:Rear Vision Camera In-Operative
This PI was superseded to update Recommendation/Instructions. Please discard PIT3862F.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2196987&from=sm#ss1-2196987">Condition/Concern:
Some customers may experience a condition with the rear vision camera being inoperative or having a blank screen when shifting into reverse. You will also notice a disclaimer at the top of the screen but the rest of the screen is black.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2196987&from=sm#ss2-2196987">Recommendation/Instructions:
Check the rear vision camera on/off selection in the customer selectable menu settings.
Press the Menu Hard key then select the Display soft key on Chevrolet and GMC Models or Press the Config Hard key then select the Display soft key on Escalade Models
To verify the rear camera setting, touch the Rear Camera Options soft key. If the bullet is blue, it is turned off and will not display the rear vision image from the camera. To turn on the Rear Camera Image in Reverse, touch the soft key. An Orange bullet indicates the camera is turned on when in Reverse.
Models:2007 -2009 Cadillac Escalade and Escalade ESV
2007-2009 Chevrolet Avalanche, Tahoe, Suburban
2007-2009 GMC Yukon, Yukon XL, Denali, Denali XL
With Navigation radio and Rear Camera System (RPO - UVC)
Here is another bulletin of interest.....
#06-08-127-002: UVC Rear Vision Camera System Inoperative (Inspect for Missing CPA Retainer and/or Properly Seated Connector/Connection at Camera) - (Nov 9, 2006)
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1871869&from=sm#ss1-1871869">Condition
Some customers may comment on a condition with the rear vision camera having a blank screen when shifting into reverse. You will also notice a disclaimer at the top of the screen but the rest of the screen is black.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1871869&from=sm#ss2-1871869">Cause
A connector position assurance (CPA) retainer may be missing from the connector at the camera connector.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1871869&from=sm#ss3-1871869">Correction
Examine the connection at the rear view camera wiring harness connector. Inspect for bent / backed out pins or a missing CPA retainer in the rear view camera connector. Repair or replace as necessary. Refer to Object Detection Connector End Views, Connector 9 Rearview Camera (UVC) in SI.
Inspect for a missing CPA retainer by performing the following steps:
Subject:UVC Rear Vision Camera System Inoperative (Inspect for Missing CPA Retainer and/or Properly Seated Connector/Connection at Camera)
Models:2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Suburban, Tahoe
2007 GMC Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
with Rear View Camera (RPO UVC)
Thanks for the responses. The unit display is set to the on position. I bought this Tahoe used (71000 miles) and one of the things I noticed was the rear trim piece above the license plate was loose before I bought it. I told them to fix that and I think they may have messed up the connection to the camera while they were working. The service manager said they would check that for free next week. So that is my next move. Thanks again for the informative response. If they don't fix it, I'll be taking off the liftgate panel and checking it out.
Got back from the dealer and they said everything is fine so far as connected goes. They really didn't know what to do other than just start working on it until they found something. I really wasn't interested in giving them a blank check to go to work with so I'm back here. One of the posts I found here said if you got this blank screen, that you weren't getting power to the camera. What wires on the plug in the power module would carry power to the camera?
