Old Jul 22, 2015, 1:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Backup camera problem
Old Dec 8, 2012 | 7:58 PM
  #21
15 Year Member
Originally Posted by hankburger
When I select the menu button I don't see option for the camera. I do have a camera as I see it on the back of the suburban. We just picked up this 2007LTZ suburban yesterday, and the dealer (ford) did check into it, but could not figure it out.
Any other ideas would be great.
AFAIK there is no rear camera pick on the menu. Are you saying that the camera doesn't display in reverse?
Old Apr 19, 2014 | 7:48 PM
  #22
07avy's Avatar
Default same issue
Hello. I am having the same problem and have replaced the camera and the module and still get black screen with the yellow bar. The only thing that wasn't done was the plastic clip on the camera harness. How important is that clip?
Old Jul 14, 2014 | 8:06 PM
  #23
mschwader's Avatar
Can anyone give any good advice on how to remove the lift gate panel? I can get my deep well 10mm sockets on to each of the nuts but it seems like they just spin with the bolt. It's as if I need to access it from the other side to keep the bolt from spinning as well. Need help in a hurry in a hurry as I have to replace it before I get rid of it. Thanks all!
Old Jan 6, 2016 | 2:53 PM
  #24
Llarche's Avatar
Default 08 chevy tahoe backup camera
My backup camera isn't working on my truck how could I fix that
Old Sep 21, 2017 | 2:18 PM
  #25
Matt B's Avatar
You've probably got it squared away by now- but the applique mounting bolts are seated in a crappy plastic housing.
To fix mine I ripped it off with a Flat Pry-Bar and JB welded the heads into the housing. Little anti-seize on the threads in case I'm ever in there again.
Old Feb 25, 2018 | 12:38 PM
  #26
Birddogem's Avatar
Default What was the fix?
Originally Posted by Chevrolet Customer Service
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> hankburger,
“in2pro” makes a great point. Would you PM your VIN, so I can look into this further for you?
Louis
GM Customer Service
How did you fix this issue? I have had the same problem.
Old Feb 25, 2018 | 12:40 PM
  #27
Birddogem's Avatar
I have the same probmem. How did you fix this?
thanks for any help provided.
Old Mar 10, 2018 | 11:25 AM
  #28
Carlos Quinones's Avatar
Default Where did you purchase the Control module? Can you share the link?
Can you share the link or information were you purchased the Control module please. I have the same problem
I have the same truck
Originally Posted by HoleInOne
Hi all. My first thread and I'm asking for help. The backup camera on my 2007 LTZ is not working. When you put it in reverse, the screen comes on and is black. The little warning at the top is on but nothing else. I took it to the dealer and they said the module was bad. I replaced the module under the seat and that didn't fix it. Is there any other module to replace? Thanks for all responses.
Old Nov 20, 2018 | 8:32 PM
  #29
Kuntry-Fried's Avatar
Default Rear Backp Camera Not Working
I have a 2017 Chevy Silverado 1500, just purchased brand new about 4 months ago. My rear view backup camera no longer works. The only thing I did was remove the license plates bulb light and insert it back in. Now the when you put it in reverse, the screen is blue and says Review Camera Needs To Be Serviced, or something closely related to it. Unfortunately in this truck, I can't find the fues box under the dashbord or under the hood. Any thing else I can check? I'm about to take it to the dealership, Iknow it's still under warranty but afraid they'll charge me .
nilsm
Aug 26, 2023 9:29 AM
jigstick
Jun 13, 2013 3:44 PM
ap53
Jan 26, 2011 11:54 AM
gambianoca
Feb 24, 2007 3:13 AM
hawaiifiveO
Oct 23, 2006 2:54 AM
