Bad Gremlin in my fuel system.
Old June 17th, 2013 | 9:33 PM
Jbarnhart's Avatar
Exclamation Bad Gremlin in my fuel system.
I have an 01 Suburban. It wouldn't start and thought my daughter ran it out of fuel as the gauge was well below E. Put 5 gallons in it and it started right up. Shut it off, walked into the house to wash my hands. When I came back out to leave, the gauge was below E again and it wouldn't start. As I was sitting there, the gauge came up, heard the fuel pump come on for a couple seconds and it started right up. Drove to the store and again, when I turned the key on, fuel gauge was dead and no start. after 10-15 seconds, gauge went live and it would start. A few days later and it will not start at all and fuel gauge stays in-op. Disconnected Batt, turned key on/off, reconnected batt...nothing.
A few weeks ago I had the fuel tank off to replace the rear brake lines aft of the ABS pump. I thought maybe I had pinched the wiring, but was skeptical that I had pinched both the gauge AND pump wires to make them both fail in exact unison. Dropped the tank again anyway to check. I am a good electrical troubleshooter. Was an aviation electrician in the Navy and have been an electrical specialists since. So I went over the wiring as I would an aircraft, but found nothing to indicate a break in continuity. For no particular reason, I had my wife turn the key on just before lifting the fuel tank back up and the fuel pump hummed-up, fuel gauge swung up and it started. Ran for a day and then wouldn't start this morning.
So, am I looking at a new engine computer or is there some small hope it may be something I'm overlooking? Do the fuel pump and gauge have a common ground run that may be causing them to fail in unison? At the end of my troubleshooting rope!
shtnfrd
August 13th, 2013 8:28 PM
tobaccoman
February 14th, 2013 4:04 PM
OtherCarASaab
September 25th, 2012 8:44 AM
maxxman04
November 13th, 2011 6:35 PM
Zed7TOne
January 28th, 2008 8:50 PM
