93 Suburban No Power to inside of vehicle.
Old Jun 15, 2013 | 1:12 PM
Stephen Bannworth's Avatar
Default 93 Suburban No Power to inside of vehicle.
Hey all, I was driving down the road and all of a sudden my truck cut out. I figured it just stalled or something, so I switched over to neutral and tried the ignition and I realized I have no power to the inside of my cab. I have headlights but no power what so ever inside of the vehicle. A/C, Radio, etc. When I turn the key, nothing? I checked the battery, its rated for 800 I have 809, so its not the battery. I checked every fuse and I am getting a good current through all of them. None are blown.
Question is, why no power to inside of vehicle. Any thoughts?
I did change the ignition switch and no luck!
Old Jun 16, 2013 | 5:48 PM
djbeatz87's Avatar
I am a bit of a newbie but I have done car stereo installs for years. Is your a/c compressor still in working order? Im not sure if its relevant in Chevys but I had several vehicles that would blow fuses and cut all aux functions because the a/c compressor coil was arching out and grounding out the whole electrical system.
Old Jun 17, 2013 | 11:44 AM
Well I figured the no power issue out. Under the hood on the passenger side there is a junction box and in that box are a bunch of ground wires. The wires are connected to fusable links and one on the links had blown. So needless to say I found out why my truck lost all power.
Now the new problem is. I keep blowing fuel pump fuses and gauge fuses. I have checked the connections and I can not see any visible shorts in the wires. Not sure where else to look?
Old Jun 17, 2013 | 11:46 PM
slimkim's Avatar
Could the fuel pump itself be bad & cause this? I had this happen once, so far. I had a new fuel pump, fuses & a gauge put in. All is functional, for now.
4x4tx
Aug 18, 2013 2:58 PM
td92burb
Jun 7, 2012 3:38 AM
kc_burban
Apr 2, 2012 6:44 AM
Exejx
Jun 4, 2011 9:46 PM
pete_dallas
Jun 23, 2008 12:56 AM
