Battery not charging high RPM
Old Mar 31, 2014 | 11:08 AM
reyetwinger's Avatar
Default Battery not charging high RPM
Hi All. When I am on the highway at high speed the voltage gauge keeps bouncing low every few minutes. If I cruise at a lower speed it stays steady. Also if I punch it to pass someone the lights will dim way down and the battery icon will light up and I get a message "battery not charging". When the rpms come back down all is normal again. Anyone have this experience? Thanks
Old Mar 31, 2014 | 12:29 PM
SabrToothSqrl's Avatar
Default Vehicle
so... is this the impala? Tahoe? Ram? year/make/model would help
Old Mar 31, 2014 | 4:23 PM
Sorry, 2003 Suburban.
Old Mar 31, 2014 | 7:01 PM
First make sure the belt is tite. Even if it's a serpentine, the idler may not be as stout as it was when new. Second get the alternator tested. Most auto parts stores will do that free.
Old Mar 31, 2014 | 7:05 PM
rmccro's Avatar
Absolutely correct. Check the belt and tensioner. The belt may be slipping and that will cause the low voltage on hard acceleration.
Old Apr 1, 2014 | 6:04 AM
Thanks. I changed out both belts, idlers, and alternator last year. I'm gonna try another alternator.
Old Apr 1, 2014 | 10:13 AM
Put in a new alternator, problem solved.
in2pro
Dec 25, 2020 11:34 PM
jlockler
Jul 7, 2013 6:41 PM
rjenvision
Mar 2, 2012 6:05 PM
JC2133
Feb 19, 2012 11:40 AM
kllawson
Avalanche
Dec 22, 2010 6:31 AM
