Blower motor quit, not the resistor module
Old Aug 26, 2015 | 4:05 PM
CougarDPS's Avatar
Default Blower motor quit, not the resistor module
2008 Suburban LTZ w/ automatic temp/fan control
Replaced the resistor with OEM replacement (still no fan operation)
There was no physical dmg detectable on the circuit board or connections for the resistor but i replaced it with a new one anyay
Hard wired fan to check function (it works)
No fuses blown
AC is cold and runs in the rear (just no front operation)
The resistor is a two plug type. Black and purple wires go to the motor. Red, black, and purple w/ white wires are the other connection.
I have 13v at the black and red wires coming from the control module, but no voltage going to the blower motor.
Please help, i've searched everywhere and i cannot find the proper wiring diagram fro this year and resistor type. Is there something behind the climate controls i should check?
Thanks
Old Aug 27, 2015 | 7:19 AM
a55bruce's Avatar
Replaced the resistor with OEM replacement (still no fan operation)...
This is not really a resistor, but rather a solid state control module. Check the speed-control voltage on the Purple/White wire. With the connector plugged-in. You should see 1V(hi) - 11V(low) as you change the fan speed settings.
cbenslay
17
Nov 6, 2021 1:31 AM
Bjj1805
Jul 24, 2015 1:54 AM
capnhooks@yahoo.com
Jan 13, 2009 6:02 PM
aeroclimb
Dec 3, 2006 9:22 PM
Bobsyouruncle
Oct 31, 2006 12:11 AM
