Brake issues with 2010 Tahoe
Old Oct 5, 2019 | 6:17 PM
baskervi1's Avatar
Default Brake issues with 2010 Tahoe
We have a 2010 Tahoe LTZ with 4WD. My wife recently started complaining about the brakes not stopping as they should and an occasional grind. I just inspected them, and the front brakes, inside and out on both sides of the car, are at least 50-60%. For the rear brakes, inside and out on both sides are around 30-40%. I didn't check the parking brakes, but that wouldn't be the issue here. I've heard the grumbling when she stops once, and this is generally after she exits the turnpike where there is a stop light. In town, she says the brakes don't feel like they used to. The vehicle has approximately 90,000 miles, and the brakes were replaced around 65,000 miles. The rotors have a small lip on the edge, but both sides are pretty smooth. Nothing looks odd there.
I've contemplated replacing the front brakes anyway, but I'm a bit suspicious there may be an issue with the boost. I've not checked the vacuum on that yet, but I thought I'd get a few ideas before I spend any more time on this. Thanks
Old Oct 5, 2019 | 7:27 PM
oilcanhenry's Avatar
Could be a warped brake rotor.
Old Oct 6, 2019 | 12:25 AM
A warped rotor would cause a pulsating pedal. I suspect a stuck caliper piston causing the pad to overheat.
Old Oct 6, 2019 | 3:27 PM
baskervi1's Avatar
Thanks for the responses.Stuck caliper sounds likely. Take care.
Old Oct 6, 2019 | 5:53 PM
Good piont. I believe you are correct.
Old Oct 15, 2019 | 6:21 PM
baskervi1's Avatar
I checked the calipers, and they seemed to be working OK. I noticed some wear on the inside tire tread, and that problem was from the left front hub. I replaced the hub about 1.5 weeks ago, and my wife has not complained about the brakes at all. She said the grinding noise and odd braking sensations are all gone. I'm not sure if this makes a lot of sense, but I'm claiming it's fixed now. Thanks for all the suggestions.
Mille Racer 69
Dec 8, 2010 8:26 PM
gotstylez
Mar 6, 2010 10:15 PM
tahoetim
Jul 31, 2008 10:51 PM
chevy3quarta
Aug 4, 2007 12:59 AM
jasonw75
Jul 24, 2007 2:22 PM
