Brake lights constantly lit on tail lights?
I have a 2011 Chevy suburban and I had the problem with the lights constantly on. After a little research I found out the brake switch is the usual suspect so I changed it. That did absolutely nothing. Upon closer examination I found one of the 4 wires leading to the brake switch cut at the plug that connects to the switch . Put it back together and it works fine now. It was not easy to troubleshoot because the plug looked normal you need to remove the tape that wraps around the 4 wires leading to the plug and pull the wires one by one to find which one is cut,take apart the plug and re solder the wire back in place.
I hope this helps some of you,it almost drove me nuts trying to find what was the problem.
I bought my 07 Suburban LT a few months back and didn't noticed it was missing the top bulbs on the taillights, I have the same issue with the brake light staying on only on the taillight, third light on top of tailgate works as it should, took it to the dealer and they told me it was the engine compartment fuse box, and of course they charged me almost $400 just to tell me that, so I bought a new one and replace it myself, and still the same, I tried everything you guys suggested and the only was they turn off is either by unplugging the fuse at the side of the dashboard or unplugging the connector at the BCM, by the way, the light bulb has two filaments, brake light and parking light and they both stay on, would it be fair to say is the BCM? thanks in advance.
According to my 2011 manuals the ground wires (black) for the tail lights go to the left frame rail, behind the left rear tire. Look on the left side of the frame. Good luck
I checked the ground cables coming from both tail lights and everything is ok, also based on the way they are wired I hardly think that could be the issue, I followed the ground cable from the frame up to the taillights and the same cable works for every other bulb, comes in on the first one and back out to the next until the last one on top which is the one I have issues with and also there are separate grounds for each side which also eliminates my issue since this problem is on both sides, so at this point does anybody think it should be safe to replace the BCM ?
I have the same issue with the brake light staying on only on the taillight, third light on top of tailgate works as it should,.... the only was they turn off is either by unplugging the fuse at the side of the dashboard or unplugging the connector at the BCM, by the way, the light bulb has two filaments, brake light and parking light and they both stay on, would it be fair to say is the BCM? thanks in advance.
Do the lights stay on when the headlights are turned OFF?
What happens when you unplug the PRK LAMP relay in the underhood fuse block?
