brake line replacement.
Old Jul 27, 2014 | 11:14 AM
2000suburbanjeff's Avatar
Default brake line replacement.
Hello ok what i'm having done.is total fuel line brake line mastercylinder abs modu
pump all 4 rubber hose.my question is i got qutoe of 1000 for labor only.rest is me buying part's 998.is this a fair price for the labor?
Old Jul 27, 2014 | 2:54 PM
If your referring to front to rear steel line replacement; sounds more than fair to me. For the steel brake lines alone I would bill 1 hour per line plus 0.5 hours to remove the old lines and bleed the system. if you have the 3 channel abs that would be 5 replacement lines (2 from the m/c to the abs pump, 2 to the front brakes and 1 to the rear) and 6 lines for the 4 channel system.
2 hours for the fuel lines.
I'm not sure of the book time for 3 flex lines or 4 if you have the four channel system....the abs pump or master cylinder.
what happened...someone put a petroleum based fluid in the brake system?
Old Jul 27, 2014 | 4:50 PM
No was northern state suv from indianapolis.and the line's are toasted from road salt along with the gm useing wrong line's not good combo.also on side note i'm going with prebent stainless steel line's
Old Jul 27, 2014 | 5:26 PM
Stainless works. I usually use copper/nickel as it is easy to work with and doesn't rust. Whenever I use steel it gets sprayed with rubberized rockerguard, otherwise it would have surface rust in 6months.
Old Jul 27, 2014 | 5:55 PM
Sorry i forgot to say in non tracion control.if wasnt such a big project i would do it.but to much for me to handle without the right tool's
Old Jul 27, 2014 | 9:20 PM
its not a job I would do laying on my back in a driveway. One line maybe, not everything front to rear.
Old Dec 30, 2015 | 9:51 PM
wogamax's Avatar
Just bumping to add that doing this job with is lift is a lot better, in part because of the long lengths, and angle of entry into the frame area. A lot of going back and forth, to feed / pull line too.
Old Jan 21, 2016 | 12:40 PM
TahoeLTGuy01's Avatar
Default I just installed dorman stainless steal kit
https://chevroletforum.com/forum/tah...e-lines-71616/
McGyver9
27
Mar 26, 2025 1:18 AM
Bigman426
Jun 5, 2015 6:59 PM
yourneighbor
Sep 15, 2007 9:51 AM
arbiestsheft
Aug 5, 2007 4:21 PM
