brake system gremlin?
Old Aug 10, 2013 | 11:00 AM
shtnfrd's Avatar
Default brake system gremlin?
The 2005 Suburban's emergency brake light (!)and traction control light suddenly came on and I had almost no brakes at all in city traffic! The pedal went to the floor and the braking power was near non existent! This went on for about ten minutes and then, as quickly as the problem appeared, it disappeared. Brake pads and fluid are fine, and the above mentioned lights turned off.
Anyone know what happened? Wouldn't it to do that again, would've been easy to crash. Thanks.
Old Aug 10, 2013 | 9:25 PM
getting the abs codes read would be the place to start. post the codes here.
did you feel the abs pump activate?
hydroboost or vacuum boost system?
Old Aug 11, 2013 | 8:20 PM
shtnfrd's Avatar
No the ABS didn't activate. Not sure what system. Will have the codes checked at stealership.
Old Aug 13, 2013 | 3:34 PM
2000suburbanjeff's Avatar
You should check your brake lines.i've heard gm cheap out and put in steel lines and not stainless steel.
Old Aug 13, 2013 | 6:49 PM
I've never seen a stainless steel line from factory from any Asian or domestic manufacturer. Which car maker does this?
Old Aug 13, 2013 | 7:28 PM
Curious as to where you found that information about GM using stainless steel brake lines. All the brake lines I've seen over the last 50 years use a special tin plated steel tubing.
Jbarnhart
Jun 17, 2013 8:33 PM
tobaccoman
Feb 14, 2013 3:04 PM
maxxman04
Nov 13, 2011 5:35 PM
Zed7TOne
Jan 28, 2008 7:50 PM
