Bug/Rock Shield Mounting Hardware
Old Sep 13, 2011 | 12:18 PM
bigbake's Avatar
Default Bug/Rock Shield Mounting Hardware
My mistake...I purchased a used bug shield for my '07 Tahoe. It came with what I thought was the mounting hardware I would need. Unfortunately I have discovered the key thing I'm missing is on my Tahoe...the rivets you put in the hood holes. (sorry not sure of the correct term)
I went the Chevy parts dept but they were unable to help me. The "install kit" they use comes prepackaged with the rivets/screws etc and you can't buy the rivets alone.
So...does anyone know if you can find these somewhere? I've been googling away but not having much luck.
Old Sep 14, 2011 | 8:23 PM
Welcome to the forum.
If you're putting it on to protect the leading edge paint, then 3M body film is a better solution as it is almost invisible.
Old Sep 18, 2011 | 10:33 PM
bigbake's Avatar
Just purchased it cause I thought I found a decent deal on a shield in good shape. I even insisted he get me the install screws...not realizing I still needed the expansion rivots on my Tahoe.
Old Nov 5, 2012 | 9:02 PM
Jochen's Avatar
had the same issue.
My 09 Tahoe got totaled and I took the bug shield off because I knew I will by an other Tahoe. The bug shield come off but the plastic inserts not.
I went to Lowes. In the special hardware section you can get license plate inserts.
The right size works perfectly and fits in the hole of the hood.
2 for 0.92 dollars
Old Nov 5, 2012 | 9:09 PM
bigbake's Avatar
Sweet. I ended up getting lucky and talking the installer at the dealer to throw me a enough to re-install it. Good deal finding em at Lowes.
Old May 12, 2013 | 9:32 AM
gto guy's Avatar
Default beg shield screws
Hey, Could you send or post pic's of what you found at lowes? Thanks
Old May 12, 2013 | 9:33 AM
gto guy's Avatar
Default bug shield screws
sourovmd7
Apr 19, 2014 4:53 PM
scott_mckinney
Aug 27, 2010 8:35 AM
fyrcaptain
Oct 6, 2009 9:15 PM
crosskeystv
Oct 17, 2006 11:29 PM
