A/C Compressor Leak
Old Jul 6, 2022 | 12:42 AM
mistersuburban's Avatar
Default A/C Compressor Leak
I have been told I have a compressor leak in my 96 Suburban with 5.7 engine. Apparently, there is a seal behind the clutch that's causing the loss of refrigerant slowly. Asking of that can be repaired at an A/C shop. Or do I have to buy a complete NEW compressor?? I'd like to avoid a major expense like replacing a compressor, if possible. Any ideas, recommendations appreciated!
Old Jul 6, 2022 | 8:09 AM
Cusser's Avatar
I think it would be cheaper, and better if you replace the compressor, especially if it's the R4 compressor. Since the compressor hasn't seized, you likely can avoid replacing the condenser and orifice tube (and accumulator, if the system has always had "some" refrigerant in it.
Old Jul 6, 2022 | 8:19 AM
Get a rebuilt compressor to save some money.
Old Jul 6, 2022 | 8:20 AM
hanky's Avatar
If the necessary tools are available that seal ,usually if there is enough room, can be replaced without removing the compressor.. Best left to a shop that has the tools.
Old Jul 6, 2022 | 9:34 AM
repairman54's Avatar
Replace the compressor for a once and done. If there is any play in the bearings or shaft damage / wear, then the seal will not last.
Latyler
May 12, 2022 10:38 PM
Karlson
16
Aug 12, 2019 2:33 PM
joeincharlotte
Mar 28, 2014 6:48 AM
a.308man
May 27, 2011 7:24 PM
hobhancock
Oct 26, 2006 5:19 PM
