A/C smell?
Old Sep 27, 2006 | 2:53 AM
thkwolf's Avatar
Default A/C smell?
Has any one experienced a musty smell from the A/C. Smells like there is mold or something when the A/C is not on interior recycle setting...
Old Sep 27, 2006 | 6:16 PM
tj's Avatar
tj
Default RE: A/C smell?
What year is your truck. I picked up an '07 las month and just started to get a moldy smell when I turn on the A/C. It was fine the first 3 weeks.
Old Sep 27, 2006 | 7:09 PM
ZX1100F1's Avatar
Most likely caused by bacteria growth in the A/C duct.
There are several products on the market that can be used to eliminate this odor.
To keep it from reoccurring it is best to turn the A/C switch to off and the blower on high for several minutes prior to shutting the vehicle off to dry the system and prevent further contamination.
Old Sep 27, 2006 | 11:40 PM
thkwolf's Avatar
My Tahoe is an '07.
Old Sep 27, 2006 | 11:42 PM
thkwolf's Avatar
ZX-
Where would I find the products to fix the smell? Would it be easier to take it to the dealer or just do it myself?
Old Sep 28, 2006 | 3:13 PM
ZX1100F1's Avatar
It's very easy to do yourself.
There are many products out there that can kill the bacteria, look at your local auto parts store for brands designed for automotive use.
You can also use Lysol but it smells bad so you’ll have to run the A/C blower on high for a while to purge the odor before taking a drive.
What you want to do is to put the A/C on high blower and draw air in from outside (recirc off) then spray the product into the fresh air inlet between the hood and windshield on the passenger side, I would remove the black plastic trim before doing this so you get good coverage and the product doesn’t damage the plastic.
Old Sep 28, 2006 | 9:03 PM
thkwolf's Avatar
Thanks Z...once I fix it is there something that I can do to prevent that from occuring again?
Old Sep 29, 2006 | 1:22 PM
ZX1100F1's Avatar
Yes, please read my first post in this thread.
clowninxs
Mar 7, 2007 8:18 PM
pojay21
Oct 13, 2006 9:00 PM
lagger
Oct 6, 2006 3:46 PM
at7driver
Sep 8, 2006 1:40 AM
crlsrod
Mar 25, 2005 12:11 AM
