can I make '07 suburban do what 08 escalade does
Old Aug 3, 2011 | 12:08 PM
RPOOL's Avatar
Default can I make '07 suburban do what 08 escalade does
My wife's '08 Escalade map lights turn on and dim off as she enters and exits the vehicle or operates her remote. I purchased a used '07 suburban with an after market dvd system installed at the exclusion of a dome light, so when I get in or out of the suburban at night it is pitch black in the cabin unless we actuate the map lights manually. That's not a big deal. but it sure would be nice if they came on automatically when the remote was pressed or the door was opened. Is there a simple way to make the map lights of my Suburban turn on like they do in my wife's '08 Cadillac Escalade?
Old Aug 3, 2011 | 4:10 PM
ousig2408's Avatar
so your map lights dont turn on and dim at all?
there is a switch right above the small dimmer dial to the left of the steering wheel - if that is pushed your lights wont ever turn on when you open the door. supposed to save the battery if you are going to be in and out a lot.
because they are supposed to do exactly what you are saying - come on and slowly dim
Old Aug 3, 2011 | 4:22 PM
ChevyFreak's Avatar
You beat me to it
Yup! I would start there first. My guess would be that the previous owner had it off and it never got turned back on. The DVD unit is irrelevant. There are several other dome lights in the vehicle (up front, and in back) that will come on with the doors open and fade out when they are closed.
Old Aug 5, 2011 | 9:43 AM
slw210's Avatar
On my 2003 Suburban they can be controlled through the DIC, seperately for each of the drivers (1 & 2).
txguykev
Oct 27, 2008 3:59 PM
didithepest
Mar 8, 2007 3:18 PM
tahoeguy98
Oct 5, 2006 4:49 PM
