Can you test the wiper motor?
Old Nov 23, 2008 | 11:00 AM
Mymarine68's Avatar
Default Can you test the wiper motor?
Can anyone tell me if there is a way to test the wiper motor and/or multi function switch on a 2003 Suburban? Thanks.
Old Nov 25, 2008 | 8:38 AM
RonH's Avatar
Default RE: Can you test the wiper motor?
Quick test procedure:
turn switch on.
works = good
doesn't work = bad
End of test.
Old Feb 25, 2010 | 3:41 AM
tekkitan's Avatar
turn switch on.
works = good
doesn't work = bad
End of test.
Nice, horrible reply. Say it's a wiring issue between the switch and the motor? Then what?
OP: I'd get a voltmeter and make sure an electric current is getting to the wires just before the motor. If so, then it is most likely the motor.
ruley73
Sep 15, 2017 8:11 AM
Cavigurl85
Oct 27, 2007 9:11 AM
