Can't figure out this loud vibration...
The vehicle is a 99 Chevy Suburban 5.7L LT, when I hit 55mph I start getting this loud vibration, sounds like loud bass.
What I've done...
got up to speed and put it in neutral- no change
turned off the vehicle going 60mph- no change
went down a dirt road going 60mpg- less noise but still there.
I'm thinking it's a tire issue, the tires are not that old but have dry cracks between the treads.
What I've done...
zoom out so the pic shows the entire tread.
most common tire noise is due to toe misalignment which leaves a saw tooth pattern either on the inner or outer part of the tire. the noise will sound like a growl, similar to a bad wheel bearing.
does the frequency of the noise change with vehicle speed?
I had a Nissan truck do something like that. the welds on the roof brace were missing and the roof was flexing.
common vibrations are tire or driveline related. if the tires check out, inspect your driveshaft ujoints.
The vibration is heard and felt through out the entire vehicle. I checked the u-joints and they feel solid. I went 65mph, put the vehicle in neutral and shut off the truck, thus taking out all components others than the tires. The vibration was still there so I'm thinking it's the tires.
