Can't get my key to turn
Old Sep 18, 2019 | 8:21 PM
Pbrouse's Avatar
Default Can't get my key to turn
I have a 2005 Suburban with 250k miles. Yesterday, the key just stopped turning, so I can't start vehicle. I also can't shift it into neutral so I can't move it out of the way.
I have googled, YouTube, and read the manual. I have bought a new lock cylinder to replace the old one. However, I have to be able to rotate the key to 'on'. I can't get the key to rotate at all.
Any suggestions or help?
Old Sep 18, 2019 | 8:23 PM
Pbrouse's Avatar
Default Added
The steering wheel isn't locked. I can turn it 6 inches in both directions.
Is there something I am missing?
Old Sep 21, 2019 | 3:50 PM
maybe the key is worn out. if you have another key try it.
I would try getting a new key cut using a code...not tracing the old worn out key
Old Sep 22, 2019 | 9:50 AM
Cusser's Avatar
Mrs. Cusser's key for her 2005 Yukon wouldn't turn either; I had a new key cut from my own key for this, which gets under 1% of the use/wear of her key. That worked for us. Mrs. Cusser generally uses a "fob" to lock and unlock doors, so hers is used just for ignition.
Note that aftermarket keys cut at the store are a softer metal than factory keys. Best would be to keep one of the original factory keys in storage and use copies for everyday use.
malicen
May 31, 2024 1:23 PM
BrianDye
Nov 11, 2016 7:22 PM
G T Igofast
Sep 3, 2013 3:46 PM
KenC
Mar 23, 2010 2:44 PM
macydoll
Jan 1, 2008 1:09 PM
