CD stuck in CD changer
Old Jun 17, 2011 | 10:57 PM
Big Daddy Natti's Avatar
Default CD stuck in CD changer
Can anyone help? I have 2 CD's stuck in the in dash CD changer of 2003 Suburban. I have read several self help sites, with no luck so far. Has anyone had sucess, oir is it time to change the player out? Thanks in advance for any help
Old Jun 18, 2011 | 9:02 AM
ChevyFreak's Avatar
You could try pulling the radio fuse. That should, theoretically allow the radio to reset itself. If it works properally the CD's should then be able to be ejected.
Unfortunately, that will not solve your problem. That is simply a minor fix. It will probably happen again within a short time if you listen to CD's a lot. The best bet would be to replace the whole unit for a new one. Of course, you could have it repaired, but it may be worth it to just get a new unit - perhaps something even better
infinity1992
Nov 3, 2007 11:43 PM
thahoeman
Nov 28, 2006 7:09 PM
VKtahoe
Nov 28, 2006 4:15 PM
thahoeman
Nov 15, 2006 4:38 PM
VKtahoe
Nov 15, 2006 10:40 AM
